A flash failure will normally not render supported EFILive controllers unrecoverable. In most cases full flashing the controller with a stock tune file that has no security options active, will restore the controller to proper working order.
Following on from our July release of CM2150 and CM2150E controller mapping and flashing, read and flash support is now available for CM850, CM870, CM871, CM875 and CM876 controllers. Customers are asked to submit any read files from these controllers so that controller mapping can commence.
EFILive is pleased to announce that the July 2018 Beta software delivers flashing via OBD-II without the need to first unlock the ECM via the J1939 under hood port. EFILive's updated flash routines now manage unlocking functions during the ECM flash process, eliminating the need to use third party methods to remove the anti-tuning Digital Signature via the under hood OEM 3 Plug Connector before programming with EFILive.
